Cheap relay switch
Discussion in 'Sensors and Actuators' started by Mike65401, Mar 6, 2020.
  1. Mike65401
    Mike65401
    Mar 6, 2020
    What kind of relay switch will be able to close a circuit when the trigger will be the wire that normally goes to the alarm/buzzer in a smoke alarm? I want to have that trigger another lower pitched sound maker since I can't hear the high pitched alarm that's normally found in smoke alarms.
  2. Bluejets
    Bluejets
    4,052
    846
    Oct 5, 2014
    There are smoke alarms available for hearing impaired with inbuilt bluetooth to drive pillow vibrators and flashing lights.
    There are also ready made units which will interface with certain smoke alarms to drive egress systems for hostels and the like.
    The interconnect (alarm) is associated with the mains wiring and should not be interfered with from the point of view of safety both from mains wiring and the proper working of the device.
    Any device added to a smoke alarm circuit must match the existing alarms.
    Just as any replacement smoke alarm must match the existing or complete system will require replacement.
    davenn likes this.
