R
Robert Baer
...or tell them to step and repeat.Are you talking about this link?
http://www.youpcb.com/index.php/order/stepone
it works for.
If I remember correctly, if you have same designs in a single file and the single gerber file is under 10cmx10cm, they would cut it for you, e.g you board is 5cm x 10cm, you can put 2 boards in your gerber file and it is still under 10x10cm.
I remember I have done it once, but not sure if there are additional cost or not, let me check my orders when I get back home.On 11/9/2013 1:15 PM, [email protected] wrote:
Try http://www.youpcb.com
Does anyone know if they will score a panel (V-cut) from the 10cm x 10cm
board ?
I need .7" x 1.1" boards, a 10x10cm panel would hold lots if they will
score the pcb for the same price.
I registered with youpcb.com.
The order form shows Board type[?] OIndividual oPanel, but I can not
select panel.
At the top of that page is says: Order type _Prototype _
So I guess that I can not order a panel from the Prototype menu.
And the Instant Quote button does is broken !
[Controller doesn't
exist/home/tiao/public_html/youpcb/Controllers/index.php.gds.php]
