Cheap, high amp dc power supply?
T
twags6
Is there any way to make a dc power supply capable of 50+ amps at
12-13.8 vdc? Basically, I'm looking for something to simulate the
power from a car without the whole battery and charger setup. Parts
express sells a nice rackmount one, but I'd rather not part with $190.
TIA
Trevor
T
Tom Biasi
TIA
Trevor
Hi Trevor,
What is the application for this supply?
If you need nice clean regulated power you can spend more than the $190.00
that you quoted.
When I worked on high current mobile transceivers I would use the battery
and charger set up, best power for the money.
Regards,
Tom
E
exxos
twags6 said:
It would mainly be for testing various equipment such as dc motors, car
amps, etc. I was looking for something with decent regulation that i
could possibly build. I've seen a few designs, but i'm not sure what
the best would be.
heres a few i found:
http://www.mitedu.freeserve.co.uk/Circuits/Power/1230psu.htm
http://ourworld.compuserve.com/homepages/Bill_Bowden/page12.htm#5reg.gif
the regulator is easy, any switchmode chip powering a external fet will do
the job, the hardest part is finding a transformer which will kick out
50amps.....
Chris
JeB
u might find something on eBay for about half that.
B
Byron A Jeff
Neither of these. Linear regulators will burn up a whole lot of power.
The 1230psu circuit above will have to dissapate 360W of power. Much less
than 50% efficiency.
50amps.....
Why not an isolation transformer like this one:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=4665&item=7509045051&rd=1&ssPageName=WDVW
The 1KVA is 66 percent more than the 600 VA the original poster requested.
And it'll be isolated.
Essentially you want to switchmode power from a 170 VDC filtered source.
But even at 90% efficiency you'll still have to get rid of 150 W of heat.
BAJ
