- Joined
- Nov 28, 2011
- Messages
- 8,393
You can learn a lot from failing when part of your circuit doesn't work as you expected. But you won't learn anything from a circuit that doesn't work at all because a small fault completely prevents all of it from doing anything useful, or which blows MOSFETs constantly.
You also need to learn a LOT before your circuit even approaches something you can actually MAKE. There are no component values indicated, except for the ICs. There are no details of the transformers and inductors. These things make or break a switching power supply.
I very strongly recommend that you start with something more straightforward, where sections of the design can be diagnosed separately, and where each small mistake doesn't result in a shower of sparks and hours of rework, with no identifiable lesson learnt.
