chassis ground definition
Discussion in 'Electronic Basics' started by [email protected], Mar 22, 2007.
  1. Guest
  2. Rich Grise
    Rich Grise Guest
    If by "normal" ground, you mean "earth ground" or "safety ground", then no.
    It's called "chassis ground" because typically it's used as the common
    negative return from the supply. (stuff used to be built on metal chassis,
    nowadays it's a layer of copper on the PCB.)
    Conceptually, it's like the difference between "ground" (the green or bare
    wire) and "neutral" (the white wire) in house wiring.
    They usually are connected together at one point (but only one!), but
    that's not absolutely necessary, if it's totally isolated, double
    insulated, all that schtuff.
    Just FYI, the symbol for "earth ground" is usually:
    The chassis ground symbol is sometimes called "common", just to avoid
    that confusion.
    Hope This Helps!
    Rich
