Charging plate capacitor to a high voltage
Discussion in 'General Electronics Discussion' started by Oseania, Feb 13, 2015.
  1. Oseania
    Oseania
    3
    Sep 18, 2014
    I have two copper sheets that are about 10mm apart from each other. The sheets are separated by air. I would need to impose a DC voltage of about 1kV between these plates. I would also need to be able to control this voltage by dropping it to around 800V in 10ms. Is this doable?
  2. VMagno
    VMagno
    7
    Feb 11, 2015
    Sounds like the Casimir effect at first. I'm sure it's possible but I can't contribute too much to that, I'll give this a bump, hopefully someone can help.
  3. duke37
    duke37
    5,364
    769
    Jan 9, 2011
    The voltages you are considering are within the properties of easily available components.
    You will first of all have to consider how to generate the voltage. This can be done by a boost converter from a low voltage or from a high voltage mains transformer. The capacitance will be very low so the current and energy requirement will be low.
    To drop the voltage a specific amount, connect a discharged capacitor across the sheets. A series resistor will set the time that is required. The capacitance required will be about one fifth that of the copper sheets.
    CDRIVE and BobK like this.
  4. CDRIVE
    4,960
    648
    May 8, 2012
    I'm disappointed in myself. I read Oseania's requirements and intentionally didn't read any replies, as I wanted to submit my own simple but clever solution. Instead I made myself another Vodka & Grapefruit, gave up and read Duke's solution. :D
    Good thinking Duke!
    Chris
    Arouse1973 likes this.
