Charging Issue
Discussion in 'General Electronics Discussion' started by crackruckles, Mar 13, 2017.
  1. crackruckles
    crackruckles
    Mar 13, 2017
    Hi guys,
    I have recently bought a drone and a solar powered backpack with a battery and want to take them with me on holidays to Iceland however the drone charges it takes about 18 hours each time which is way to slow.
    Here is the specs of the solar backpack's battery
    output: 12V/4A , 14V/3.5A , 19V/3A
    The drone requires the following input
    13/26V 9A
    I was wondering if there is any kind of converter i could build or buy that would make this work?
    [mod edit -- moved to correct forum ... edited pix]
  2. BobK
    7,682
    1,688
    Off topic I know, but let us know how it goes when you go through customs carrying a drone. Could be interesting.
  3. Audioguru
    Audioguru
    3,388
    732
    Sep 24, 2016
    Maybe you are trying to charge the big battery with a little solar panel on a cloudy day?
    The output from the battery (at noon in the Sahara Desert (on the equator of earth) on a sunny day?) is only about 3.2A. The car power supply for the drone needs an input of 9A. So if the solar thing is making its maximum output (I doubt it) then the charge time is almost 3 times longer than normal.
