charging internal battery in led light
Discussion in 'Power Electronics' started by EricWalker, Jun 3, 2013.
  1. EricWalker
    EricWalker
    6
    Dec 5, 2012
    I have specialty lighting that works cordless- 12vdc - The battery in the light is charged via 120v with transformer to 12vdc. I am trying to diagnose what went bad on the board because now the light will only work when plugged in..I tested the internal battery and that is holding a charge. The light will not turn on using the battery. Nothing in the circuitry looks burnt out and the fuse is ok..
  2. davenn
    davenn Moderator
    13,833
    1,950
    hi there :)
    how did you measure the battery .... with or without load ?
    show us some sharp well lit pics of the circuit
  3. EricWalker
    EricWalker
    6
    Dec 5, 2012
    LED Light battery
    Hello,
    I test with and without load - measuring the same.
    I do not have schematics or detailed instructions - brought them through wholesaler - made in china..
  4. CDRIVE
    4,960
    652
    May 8, 2012
    Not that it's related but one of your photos appears to have a microphone in the upper right corner of the PCB. Does this lighting system employ a a sound activated mode?
    Chris
  5. EricWalker
    EricWalker
    6
    Dec 5, 2012
    led lights
    Yes it does..
  6. CDRIVE
    4,960
    652
    May 8, 2012
    Where in those photos does the battery and the mains tie in?
    Chris
