B
Brian J. Murrell
I have a NiCd battery. The charger that came with it seems to have given
up the ghost (died) and I need to charge this battery.
This battery a 14.4v battery pack and I am told by the manufacturer that
it has a 1.5Ah capacity. The charger that comes with the battery
recommends charging for 3-6h so it seems like they are doing a C/3-C/5
charge.
I have a battery charger that has selectable charging voltages and
current, but it only goes up to ~10v. I'm assuming this is no good to me
for this battery pack as I'm assuming I *have* to charge at the full 14.4v
for the required time given the selected current (i.e. the C/n charge rate).
I do have available to me a DC power supply that allows me to select (i.e.
via analog dials) both output voltage and current. Would this be suitable
to charge this battery pack? Should the voltage be set at 14.4v or some
value lower/higher?
Thanx,
b.
charge.
value lower/higher?
Thanx,
b.
