hey all,
I've recently followed through on that new repeater design for the radio network at cadets (old forum post) however the plans have changed slightly from the original post since I have now realised that the repeater has two dc inputs one for backup (I assume for a 12v battery backup) and a dc in which must have been used for a plug pack long ago.. however since this whole repeater setup has been moved from section to section I have lost all the manuals and the original dc plug.
I have successfully set up the repeater with one 120Ah battery (for daytime use) and one 80ah battery (for nighttime use) this also has a solar charge controller by redarc hooked up which allows me to check battery levels and charge via solar if need be.
my questions are
- is there a way or a device that I could use to charge both batteries from 240v at the same time without putting them into parallel or series.
- what would be the best way of isolating both batteries from the load without isolating any 240v charging circuitry
- what over discharge device would be the best for something like this? and would I need 2 or could it somehow be used with one?
- is there anything from a professional perspective that I am missing? I am totally open to constructive criticism
additional info
- all cables used in the setup are rated for 30A loads
- the load will be pulling 18A max (while Transmitting and receiving)
- the reason for the lower Ah battery during the night is because there is barely any radio comms and such a bigger battery isn't needed
-the repeater/load is a Kenwood TKR-751 repeater
- the whole assembly has been modified to fit into an army CP box for waterproofing as well as ruggedness.
- both inputs are being used on the repeater by a battery meaning that the "DC IN" is the 120Ah and the "backup" is the 80Ah
Regards, Lightshow
my questions are
additional info
Regards, Lightshow
