charger with adjust. float voltage???
R
Robert Morein
Are there any chargers that have an adjustment for the float voltage?
The Samlex chargers allow one to select a boost voltage of either 14.3 or
14.9, but the float voltage is fixed at 13.8.
Is 13.8 optimal for both AGM and flooded batteries?
K
Ken
either 14.3 or 14.9, but the float voltage is fixed at 13.8.
Depends on battery temperature.
R
Robert Morein
Can you recommend a flexible, portable charger for a small bank -- say 220
ah at 12V ?
S
Steve Spence
I have a 50 amp charger I took out of a rv, to replace the smart charger I
got from Wal-Mart that took a lightning hit. The Wal-Mart smart chargers are
a 4 step charger that work fine. reasonably priced, will work great on your
pack. My pack is 600 ah at 12v.
Steve Spence
Renewable energy and sustainable living
http://www.green-trust.org
Discuss vegetable oil and biodiesel
powered diesels at
http://www.veggievan.org/discuss/
R
Robert Morein
Just searched the Walmart website but I couldn't find it.
B
Bob Adkins
Check with the battery manufacturer.
-- ron (off the grid in Downeast Maine)
I think AGM calls for a tad more, but 13.8 is fine for both. They do fine on
car charging systems.
R
Robert Morein
Ron Rosenfeld said:
What objection do you have with checking with the manufacturer, as I
recommended.
Your response that "13.8 is fine" (2.30VPC) is higher than the recommended
float voltage for Surrette LA batteries (2.20-2.23VPC) and also higher than
the recommended float voltage for GNB Absolyte IIP batteries (2.25 VPC).
With the Surrette cells, a three-stage charging process is recommended.
There's probably little problem with using the higher float voltage on the
LA batteries, except water consumption will be higher than it needs to be.
So, especially with smaller cells, that'd have to be checked more often.
Also, having only a single voltage output charger will result in longer
times to recharge than is necessary. This may not be an issue in a backup
system that is used rarely. It may be an issue in an off-grid system that
is regularly cycled to, let us say, 50% DOD or more.
I'm not familiar enough with the GNB construction and chemistry to know
what using the higher float voltage will do, nor do I have data regarding
how they should be recharged.
Looks like I'll be getting a set of Hawker VM's, and the charging
recommendation is strange indeed.
They seem to mandate a pure single step constant voltage charge without
modes.
W
William P.N. Smith
modes.
That's not so strange, as their current acceptance rate is a lot
higher than other batteries. Of course, since your supply will have
some intrinsic current limit, you'll end up with what the charging
industry calls a 2-stage charger, constant current at the limit and
than constant voltage at the float voltage.
R
Robert Morein
You're right!
They will charge at 100 amps up till the float voltage!
B
Bob Adkins
recommended.
You talking to me?
If you're talking to me, I do as I fucking well please. OK?
I just watched "Casino" for the 7th time, and you picked a bad time to get
testy with me. :)
N
no useful info
no useful info said:
Path:
internal1.nntp.dca.giganews.com!border2.nntp.dca.giganews.com!border1.nntp.dca
.giganews.com!border2.nntp.sjc.giganews.com!border1.nntp.sjc.giganews.com!nntp
.giganews.com!local1.nntp.sjc.giganews.com!news.giganews.com.POSTED!not-for-ma
il
NNTP-Posting-Date: Fri, 02 Jul 2004 23:54:50 -0500
Reply-To: "no useful info" <[email protected]>
Newsgroups: alt.energy.homepower
References: <[email protected]>
<[email protected]>
<[email protected]>
<[email protected]>
<[email protected]>
<[email protected]>
Subject: Re: charger with adjust. float voltage???
Date: Sat, 3 Jul 2004 00:54:49 -0400
X-Priority: 3
X-MSMail-Priority: Normal
X-Newsreader: Microsoft Outlook Express 6.00.2800.1409
X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2800.1409
Message-ID: <[email protected]>
Lines: 45
X-Trace:
sv3-7sLHyTPCKo3vRaZO11yzxfVU2VTKm3Nmbeoo1IuUYDNyL7/q++ICnYpNFF+/aMMJ+LCyxrThmK
hrgFR!G8av7JtMxc9XeeiJvMm6MybqaGJjR2A2kZ3R/9eY3Gl91mYH7nwScnWrTndt
X-Complaints-To: [email protected]
X-DMCA-Notifications: http://www.giganews.com/info/dmca.html
X-Abuse-and-DMCA-Info: Please be sure to forward a copy of ALL headers
X-Abuse-and-DMCA-Info: Otherwise we will be unable to process your complaint
properly
X-Postfilter: 1.1
Xref: number1.nntp.dca.giganews.com alt.energy.homepower:97331
Since I started this thread, I've learned a bit that indicates how critical
AGM batteries can be with respect to float voltage.
my sense of your abilities precludes the concept that you are capable of
learning anything
I would never use X-Newsreader: Microsoft Outlook Express 6.00.2800.1409
although the anti-semite "Robert Morein" <[email protected]> who
regularly posts in rec.audio.opinion, rec.arts.movies.production.sound,
rec.audio.marketplace, misc.writing.screenplays and delights in forging
posts, does.
R
Robert Morein
Ron Rosenfeld said:
Cheap chargers have fixed set points.
If you get a Trace inverter, it may have a built-in charger which has
adjustable set points.
As indeed I have, a Xantrex SW4000.
The Outback MX-60 also has this.
N
no useful info
Ron Rosenfeld said:
You should be all set then.
nah, he'll have tons of questions: "how do I connect it to...?"
