Charger / Power Pack
Discussion in 'General Electronics Discussion' started by spike47, Jun 2, 2012.
  1. spike47
    spike47
    11
    Aug 11, 2009
    Hi
    I buy Broken Laptops and Repair them ( not all ! ) as a hobby , the question I have at the moment is that I have a Laptop repaired and ready to fire up , but I do not have the correct charger / power supply for it .
    It requires a 19V 4.5A supply , now I have a couple of chargers but they have a 19.5V 4.5A output , would that extra 0.5 V make such a difference as to blow the Laptop ! .
    thanks
    spike
  2. davenn
    davenn Moderator
    13,833
    1,950
    Hi Spike
    welcome to the forums :)
    not likely as most laptops have a bunch of voltage regulators in them anyway to produce the required various DC rails.
    i would suspect that + - 0.5V would most likely be well within the specs of the supply anyway
  3. davenn
    davenn Moderator
    13,833
    1,950
    dang mate
    I just noticed your join date ! where have you been hiding for the last 3 years
  4. spike47
    spike47
    11
    Aug 11, 2009
    Hi davenn
    Thanks for your reply , I am very tempted to use the other power pack's but I still need a bit info as to whether it will be ok , I am more or less 100% sure it will be , the reason I am dithering is that I checked the Voltage of the spare power packs I have and they showed one at 19.8V and the other at 19.9V , so I am talking about nearly a 1V difference now , yes i know I should just go and buy a new one for a couple of our £s , but I like to push and try things out its just me .
    cheers
    spike
  5. (*steve*)
    25,496
    2,837
    19.8 and 19.9? that's only 0.1 volt.
    Perhaps you mis-typed.
  6. khankll
    khankll
    110
    Feb 6, 2011
    that is not a big difference i have tried such thingas in past have had no issue..
    however if u damn want to reduce it then a power diode which can easily handle this current can be attached in series.. diodes often have .5v forward voltage drop.. in this case u will get exact voltage that u want..
