L
Larry Bradley
I need to charge the 12 volt engine start battery in my sailboat from
the 12 volt house battery in the boat. The house battery is the one
connected to the alternator. I can't just parallel the two batteries
for charging, since the house battery is a long cable run away from
the alternator, and when a heavy charge is going into the house
battery(50 amps or so), the voltage that the start battery would see
could be as high as 15.5 volts. I only need to supply about 3 amps
when the engine is running, just enough to run the fuel pump and
ignition.
I can use a linear regulator, of course. But I thought perhaps I could
use a pulse width modulator driving a switch (FET ot BJT) to apply the
15 volts to the battery in pulses, with the average voltage being
around 13.6 volts. (Sort of a switching regulator without the
inductor).
If I had the battery home with me, I could test the idea. But it is
100 miles away.
Any battery experts out there who would care to comment?
Larry Bradley VE3CRX
Remove "removeme" from my e-mail address for direct mail
Ottawa, Canada
(use the e-mail address above to send directly to me)
ignition.
inductor).
100 miles away.
Ottawa, Canada
