characteristics P6KE200A
Discussion in 'Power Electronics' started by Bluejets, Jul 14, 2019.
  1. Bluejets
    Bluejets
    4,993
    1,048
    Oct 5, 2014
    Have an smps out of a HP Compaq with no output.
    Tracked down to no startup voltage whatsoever. Checked all surrounding components which appear ok.
    Curious about the ( TVS) P6KE200A diode as it shows a similar diode in the attached schematics.
    Actually the circuit below is almost identical in the HP unit which uses a TNY268 switcher.
    Diode tests ok as far as diode test is concerned but both in the schematic below and on the board in question it is shown with zener characteristics.
    I removed the diode and tested it on a zener tester which showed 12.9v.
    Am I barking up the wrong tree here or should the P6KE200A not be higher than that and how would one test it anyhow...?
  2. Martaine2005
    Martaine2005
    3,557
    967
    May 12, 2015
    There is an article on testing a TVS that @Harald Kapp linked to a few years back.
    May be of use to you.
    Martin
  3. Bluejets
    Bluejets
    4,993
    1,048
    Oct 5, 2014
    ok...thanks...
Similar Threads
Loading...
