T
Terry Ilardi
I have a Tek 2235 scope (military version) on which I suddenly lost the
A channel. I get a nice flatline trace for channel A. The B channel
works fine.
I need to troubleshoot this but was looking for suggestions as to where
to start. It went out quite suddenly (I was switching the test leads
from from A to B and then back to A when it happened). I was wondering
if the failure might have been induced by a static discharge.
If anyone knows of typical components in this scope that are likely to
fail and cause this problem, I would appreciate hearing from you. Also,
since I don't have a spare scope to troubleshoot with, if anyone has any
suggestions as to how I should proceed with just a DVM, signal generator
and other typical test equipment, I would appreciate it.
Thanks.
Terry Ilardi
works fine.
Thanks.
Terry Ilardi
