- Joined
- Nov 28, 2011
- Messages
- 8,393
OK. You can get more control over how the light affects the motor speed on the 443 model if you remove the speed control trimpot and replace it with a circuit containing the LDR, one or more resistors, and possibly other components as well.
The 423 model is not so easy to modify. Can you use two 443 models?
I'm assuming you want the walkman to play at normal speed when the LDR is illuminated, then when people get close to the exhibit, they will block the light, and you want the walkman to slow down. Right?
A simple connection that you can experiment with is as follows. Refer to the first diagram in post #16 on this thread. Remove the motor speed trimpot; connect the LDR between the trimpot pad that connects to R604, and the trimpot pad that connects to pin 11 of the IC; connect a resistor of around 33k between the trimpot pad that connects to R605 and the pad that connects to pin 11 of the IC.
You may want to solder some thin insulated wires to the pads and make the connections off-board so you don't damage the board with too much heat.
This will control the motor speed so that when the LDR is brightly illuminated, the motor will run fast - faster than normal, and when the LDR is relatively dark, the motor will run quite slowly. You can adjust the value of the resistor to change the scaling between illumination and motor speed; increase the value to get faster motor speed for a given amount of illumination. Or you could replace the resistor with a trimpot of around 100k.
This might be kind-of what you want, but I assume you want the motor speed to be stable and correct over a moderate range of illumination on the LDR. Otherwise, variations in ambient light would cause changes in speed. This can be done, but not easily. Some external circuitry would be required, and it might need a separate power source.
Actually that made me think of possibly a simpler solution. Just varying the DC voltage you supply to the walkman will vary the motor speed. This will probably only work for the 423 model, because the 443 uses a stepper motor which will probably just stop if the supply voltage gets too low.
In the 423 model, the speed regulator tries to keep the speed correct by regulating the DC voltage to the motor. If the supply voltage drops too low, it can't provide enough voltage to the motor, and the motor slows down. This is exactly what happens when the batteries are nearly dead. So, varying the DC supply voltage might be a simple way to control the speed of the 423.
Have a think about this, and see if you can describe the exact behaviour you want from the walkman motors, and how you think you might set up the LDRs.
