Changing DC voltage
Discussion in 'Electronic Basics' started by [email protected], May 16, 2006.
  1. Guest
    I know next to nothing about electronics, so my question may be very
    basic, but here goes.
    Is there an easy way to change DC voltage? For instance, if I have a 2
    volt light and a 12 volt power source, I assume I would burn out the
    bulb if hooked into the circuit. I know AC would use a transformer, but
    not sure how it is done with DC.
  2. Chris
    Chris Guest
    Hi, Tom. The quick answer is, "Use a series resistor".
    Here's how it works. Let's say your two volt bulb has a resistance
    when hot of 2 ohms (view below in fixed font or M$ Notepad):
    | | 1 amp |
    | | | 2 ohms
    | --- ( X )
    | 2V - '-'
    | 2V / 2 ohms = 1 amp
    (created by AACircuit v1.28.5 beta 02/06/05 www.tech-chat.de)
    Using Ohm's Law ( I = V / R ), we can infer that when the bulb is hot,
    1 amp will be going through it.
    You have seen that, if you connect the 12V battery to the 2V bulb, too
    much current will go though it, causing it to burn out. We need to add
    something else to the circuit so the total current going through the
    bulb remains 1 amp.
    That something is a series resistor. Again, using Ohm's law, we can
    find the total resistance we need:
    1 amp = 12 V / ? ohms
    You can easily see that ? should be 12 ohms. That would mean we have
    to add a 10 ohm resistor in series to make the total resistance 12
    ohms, like this:
    | ___
    | .----|___|-----.
    | | 10 ohms |
    | | 1 amp |
    | | | 2 ohms
    | --- ( X )
    | 2V - '-'
    | 12V /( 10 ohms + 2 ohms ) = 1 amp
    If this isn't just a homework problem, you'd also have to size the
    resistor properly for the power dissipation.
    Good luck
    Chris
  3. Pooh Bear
    Pooh Bear Guest
    But this is wasteful of energy. In this case only 1/6 of the power f om the
    battery reaches the bulb.
    A better solution would be a switching regulator but why not just use a 12V bulb
    Where did you find a *2 Volt* light btw ?
    Graham
  4. Ralph Mowery
    Ralph Mowery Guest
    To go from a higher voltage to a lower one there are 2 simple methods. If
    the current is low and constant then a resistor would do it. A much beter
    way is a voltage regulator. For currents up to about 1 amp you can use a 3
    terminal voltage regulator. Look up a LM7805. I know of some 5 amp
    regulator ICs. For greater current (up to 50 amps and more) you can use a
    LM723 IC and a few transistors. The basic circuit has been around for 20 or
    30 years. Still being used.
    Start here and then look at some of the circuit diagrams.
    http://www.repeater-builder.com/astron/astron-index.html
    To get a higher DC voltage you usually convert it to an AC voltage , send it
    to a transformer (which can be part of the DC to AC converter) , then change
    it back to DC.
  5. JeffM
    JeffM Guest
    2 volt light and a 12 volt power source
    This reminds me of the old joke
    "Y'know, if they'd just hire taller girls
    those ballerinas wouldn't need to stand on their toes."
  6. Chris
    Chris Guest
    Hi, Graham. It sounds like a homework or science fair question.
    Considering the time of the year and the way the question is phrased, I
    was guessing it might be a basic level high school physical science
    question. Some high school sequences cover electricity toward the end
    of the second semester.
    Let's not scare 'em off too soon. ;-)
    Cheers
    Chris
  7. How do you convert DC to AC?
  8. Pooh Bear
    Pooh Bear Guest
    You 'chop' it.
    Graham
  9. You use switches to reroute it in alternating directions.
    Actually, you don't need to actually reverse the direction of current,
    you can just interrupt it and use inductance and capacitance to work
    with those changes to generate more voltage.
    Here is a tutorial that covers some of the circuit physics involved:
    http://www.national.com/appinfo/power/files/f5.pdf
