changing amperage
Discussion in 'General Electronics Discussion' started by Mohamed_white_side, Feb 8, 2011.
  1. Mohamed_white_side
    Mohamed_white_side
    Feb 6, 2011
    if a modem for example needs 0.8A ... and i replaced it with a cable of 1A ...
    but with the same Tension in both cases ...
    whats gonna be the difference ?
  2. shrtrnd
    shrtrnd
    3,827
    524
    Jan 15, 2010
    What's 'Tension'?
  3. Transistor
    Transistor
    Jan 28, 2011
    re:
    In this case I don't think it would make a huge difference... but don't expect that modem to last very long. The higher amps even if slight will wear on the componenets quicker... at least thats what my logic tells me...
  4. (*steve*)
    25,501
    2,841
    Transistor: Your logic is wrong.
    shrtrnd: Maybe the OP meant "Voltage"?
  5. shrtrnd
    shrtrnd
    3,827
    524
    Jan 15, 2010
    *steve*, Yeah, I kinda figured that's what he/she meant. I was wondering what kind of
    class the person was taking, that would use that term. Physics maybe?
  6. (*steve*)
    25,501
    2,841
    shrtrnd: I'd say it's a language issue.
    Mohamed: I think your native language is not English. Some of your words seem wrong. I am not sure exactly what you mean.
    Do you mean: Replacing a cable with one that can handle a higher current?
    or
    Replacing the power supply with one of the same voltage but able to supply a higher current?
    Both are safe.
    You would expect normal operation. The device being powered will only draw as much current as it needs.
  7. Mohamed_white_side
    Mohamed_white_side
    Feb 6, 2011
    Sorry about My English , it's not my native language , and I'm trying to improve it actually .
    Well , what I meant is , I have a modem supplied by a cable of 0.8 A , and I changed this cable by an other one with 1 Ampere , but the voltage of the two power supplies is the same .
    So , can a small difference in Amperage influences on its performance ?
    thank you very much
  8. (*steve*)
    25,501
    2,841
    No, as I said above: "You would expect normal operation. The device being powered will only draw as much current as it needs."
    A power supply capable of supplying 1A will only deliver 1A if the load demands it. If the load was previously running from a 0.8A supply then it obviously required 0.8A or less. It will draw the same from the larger power supply.
