Changing 3 volt LED
Discussion in 'Electronic Repair' started by Neil Purtnoy, Sep 30, 2004.
  1. Neil Purtnoy
    Neil Purtnoy Guest
    What size resistor should I use to change a 3 volt LED to a 5 volt LED?
  2. If you mean an LED that has a voltage drop of 3 V or 5 V:
    Need to know the present resistor and input voltage, or the current (I).
    If the current is known, you need to decrease the resistor by an amount
    equal to 2/I.
    --- sam | Sci.Electronics.Repair FAQ Mirror: http://repairfaq.ece.drexel.edu/
    Repair | Main Table of Contents: http://repairfaq.ece.drexel.edu/REPAIR/
    +Lasers | Sam's Laser FAQ: http://repairfaq.ece.drexel.edu/sam/lasersam.htm
    | Mirror Sites: http://repairfaq.ece.drexel.edu/REPAIR/F_mirror.html
    Note: These links are hopefully temporary until we can sort out the excessive
    traffic on Repairfaq.org.
    Important: Anything sent to the email address in the message header is ignored.
    To contact me, please use the feedback form on the S.E.R FAQ Web sites.
  3. Neil Purtnoy
    Neil Purtnoy Guest
    The input power going to the LED is 5 volts from computer power supply, the
    LED is 3 volts,(there never was a resistor connected) someone told me to
    change the 3 volt to 5 you have to add a resistor)so if I use it that way,
    won`t the 5 volt power burn out the 3 volt LED? "Sam Goldwasser"
  4. Neil Purtnoy
    Neil Purtnoy Guest
  5. Maybe, you need an additional resistor but without knowing the exact
    current, can't give an exact resistor. Assuming 10 mA, use a 200 ohm
    resistor. 10 mA is safe for most LEDs.
  6. NSM
    NSM Guest
    the
    way,
    220 ohm is probably the nearest standard value. 1/4 watt will be fine as a
    rating. If it's too dim, go to 180 or even 150 ohm. The LED probably has a
    built in resistor.
    N
