Damian said:
Yes, but most of you 'black' guys can handle it. ;-)
It's mostly in Australia we should be worried about this UV sun thing. I believe most of the habitable other areas of the world is
ok.
The UV exposure index in Australia is no different to other parts of the world with
the same conditions (latitude, altitude, clouds etc.)
http://www.who.int/uv/intersunprogramme/activities/uv_index/en/index3.html
BTW We have all seen media beatups about the Antarctic ozone layer "hole",
suggesting that it massively increases UV in Australia and is to blame for skin cancer rates.
That is simply not true, as this link explains:
http://www.met.sjsu.edu/~cordero/ozone/MSIE_paper.pdf
I believe the darker your skin, the better protection you might have against UV in under Australian sun.
That is true for any where in the world, not just Australia.
All fair skinned people are at increased risk if they move closer to the equator,
as happened when the Poms moved here.
I rarely hear aborigenes getting skin cancer, by that I meant the real Aborigenes. Not the 5% Aborigenes.
The skin cancer mortality rate for aborigines is about a quarter of the non- aborigines.
But aborigines die much younger anyway.
On another topic, has anyone used BUNGARD photo-resist pcbs and what is a
cheap UV source to expose with? (Other than the Sun.) Aldi had a cheap UV steriliser
a few years ago which worked with UV EPROMs, but it's too small for PCBs
Anyone tried cold cathode UV tubes?
