T
Travis Evans
Just wondering, do CFLs usually go into a "works sometimes" mode rather
than completely not working at all? I've only seen a few CFL failures
so far, all of which were the "just stopped working upon switch-on"
type*... but it seems like in a couple of cases they acted as if they
couldn't make up their minds whether they were truly burnt out or not.
For instance, we have two Commercial Electric "daylight" (high
color-temperature) CFLs installed in a fixture above the sink (we've
had them for a couple of years). I just noticed that on some days one
of them doesn't work at all, and others it does work and gives off full
light output without flickering.
In the past there was an occasion (this was the first CFL failure I had
ever witnessed) where a GE CFL that was in a bathroom (which admittedly
was a windowless bathroom where the lights were switched quite
frequently) that very briefly lit up on switch-on, then went out and
remained out thereafter. I may have tested it in another fixture to
make sure it had failed (I don't remember for sure), but I was somehow
sure it was dead for good. For some reason I stored it away instead of
throwing it out, and one day I took it out and put it in a lamp and
turned it on just for the heck of it, and I was surprised when it lit
up! We put it in a living room lamp and it continued to work for a
while, albeit with seemingly slightly lower light output than when new.
I don't remember what happened to that one; it might have died again
later on.
* with the exception of a 2-3 month-old Lights-of-America 3-way CFL
which didn't completely stop working, but which gradually and
dramatically lost light output over time until it was no longer useful
later on.
