cf versus 1156
Discussion in 'Home Power and Microgeneration' started by John Smith, Apr 1, 2006.
  1. John Smith
    John Smith Guest
    I finally got around to testing the amps draw at 12 volts
    The Ultra mini CF draws half of an 1156 using a cheap Canadian tire
    inverter.
    Yahoo camping season is here
  2. GeekBoy
    GeekBoy Guest
    With "Survivor Man" its always camping season.
    *** Free account sponsored by SecureIX.com ***
    *** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com ***
  3. Vaughn Simon
    Vaughn Simon Guest
    I would be interested in seeing your numbers. The 12 volt CFs I use take about
    one amp and have been running daily for several years now.
    Vaughn
  4. Richard P.
    Richard P. Guest
    That guy is cool..!
  5. John Smith
    John Smith Guest
    The Ultra mini CF 9 watt a 40 watt incandesent equal draws point 8 of an amp @12
    volts. Half of my 1156 bulbs in my camper. I dont think my DC amp clamp is very
    accurate though but it shows half and probably ten times the light. I am using one
    of those cheap CT digital read 800 watt inverters.
  6. Ecnerwal
    Ecnerwal Guest
    Based in part on comments by Neon John, I went and looked at 12V cold
    cathode tubes (and discovered the really weird concept of "hot-rodding"
    a PC, which I'm afraid looks just stooo-pid). Anyway, the units sold for
    that seems to be generally cheaper than the ones sold for lighting up
    the underside of cars (also stooo-pid, IMHO), although a light-meter
    comparison might be worthwhile (to check watts in .vs. light out and
    figure out which is better on that front). Supposed draw is 3.5 watts or
    so, I have yet to hook up an ammeter and check them. They start a little
    slow (well, they light right up, but take a while to get to full
    brightness). 2 12 inch (30cm) long tubes and a 12V inverter to drive
    them at 600+ volts for 8 bucks or so, if you shop around. Supposed to
    have 30,000 hour life. White and many colors, though some vendors carry
    very few colors; get the bug-lite yellow for the outside door, and put a
    black-light one somewhere else to draw the bugs away?
  7. John Smith
    John Smith Guest
    I have one of those mini dual tube 12 volt fixtures in my camper allready.
    It sucks about 2.5 amps dc.........gonna replace it with a Ultra compact and
    put on my inverter.
  8. I was pretty underimpressed with the ones I got for my wife's golf
    cart. 8*) Can't imagine using them for house lighting.
  9. You
    You Guest
    He is "cool" only if he can't get his fire started.........
