TCP makes some very good dimmable fluorescent lamps that work with standard
incandescent dimmers. I've been using for my kitchen track lighting for
over a year with no problems or failures.
Goodmart has quite a variety, but you buy them by the case of 6. I'm using
the Uniflood R30s and a few R40s.
If the "bulb" does burn out, you can replace just that part using a four pin
spiral replacement.
These come on plenty bright immediately, with no flicker. Some flickering
occurs if you dim too low, especially when cold. Good warm color, but color
get whiter if you leave them full-on for a long time.
http://www.goodmart.com/products/bulb_compact_fluorescent_screw_in_base_dimmable.htm
I'm going to try the dedicated dimmable track lights. A great price value!
http://www.goodmart.com/products/Track_Light.htm
buylighting.com also carries TCP dimmable CFL's, and you can order them in
onesies.
--David Bangs
George Elkins said:
I realize it's slightly off-topic, but are there any dimmable CFs? I
haven't seen any yet in Home Depot/Loews.
George Elkins
