Ceramic resistor information
Discussion in 'General Electronics Discussion' started by boxedj, Dec 3, 2015.
  1. boxedj
    boxedj
    Dec 3, 2015
    Hi, I'm trying to get some information about this ceramic resistor.
    Specifically I'm trying to learn about the amount of heat that the thing might produce, but any electrical information about it will help point me in the right direction to find that info.
    The markings on the side say 10(1/2)D21WLC
    Any clues?
    Thanks in advance!
    [​IMG]
  2. Alec_t
    Alec_t
    2,936
    799
    Jul 7, 2015
    That depends of the resistance and the current through it. Power dissipated = resistance x current-squared.
  3. AnalogKid
    AnalogKid
    2,476
    714
    Jun 10, 2015
    One that size is rated for at least 100 W steady state dissipation.
    ak
  4. boxedj
    boxedj
    Dec 3, 2015
    Ah so those numbers don't actually say anything its just like a serial number then? Should I just go by pictures of similar sized?
    I'll search up heat info at 100w dissipation as well, thanks AK.
  5. davenn
    davenn Moderator
    13,787
    1,937
    well the 10 at the start is probably indicating resistance ---- 10Ω
    confirm that with a multimeter in Ohms range
