Centering output with a cap,then to comparator ..???
Discussion in 'General Electronics Discussion' started by wannabegeek, Jun 16, 2013.
  1. wannabegeek
    wannabegeek
    133
    Aug 17, 2011
    hi all....
    I 'm stuck with something that seems pretty basic...
    I have a triangle wave coming out of an active filter that's all above zero, Vpp = 0 - 2 V.
    I want to connect that output to a decoupling cap to center the signal again, so that
    Vpp = -1 - 1 V.
    Looks great on the scope...Next, I want a comparator to get make a square pulse train that swings both pos and negative.
    This is where I fail, as the input impedance on the op amp comparator
    is huge and the cap just charges up.
    How is this done...?
    TIA,
    wbg
  2. (*steve*)
    25,496
    2,837
    You need to provide a DC path from the input of the op-amp to ground.
  3. wannabegeek
    wannabegeek
    133
    Aug 17, 2011
    Yes, that sounds like a basic ...thanks Steve...that makes total sense...
    Did I mention that my electronics background comes from one crash course
    in a physics program...?
    If I get my project to do something interesting I'll start a thread in the projects section to
    "show it off"...
    Cheers !
    wbg
  4. wannabegeek
    wannabegeek
    133
    Aug 17, 2011
    Trying out the "fix"...
    I tried putting the DC path at the input of the OP AMP...no luck.
    But I did stick a 1M Ohm resistor to ground and that worked. I'm
    using a 0.1 micro F cap.
    In fact, this solution makes more sense to me...blocking caps in general never seem to work for me as initially expected.
  5. wannabegeek
    wannabegeek
    133
    Aug 17, 2011
    It appears that I'm stuck with this again...
    I've attached a schematic...
    The input is actually a photo-diode with op-amp for gain. I'm sending a PWM
    20kHz carrier via 650 nm laser diode. The photo-diode receives this pulse, which has a lot of chatter in it, and gets sent to the filters.
    To keep the schematic simple, I just put an AC voltage source in.
    I'd like to not use a negative voltage source. I'm using an OP07 op amp, and wondering if I should be using uni-polar op-amps....
    I've got the circuit working when using a negative supple and no voltage divider.
    I don't see why I need a negative supply though.
    [​IMG]
    Thanks again,
    wbg
  6. (*steve*)
    25,496
    2,837
    Yep, that's what I meant. The input of the op-amp requires a DC path to ground (or to a virtual ground).
  7. wannabegeek
    wannabegeek
    133
    Aug 17, 2011
  8. wannabegeek
    wannabegeek
    133
    Aug 17, 2011
    I totally forgot about setting all the f_3dB points...I was taught how to bias a transistor in school...the application note I posted covers it.
    I got the circuit to work with a single positive supply....and it wasn't worth it...
    too many more parts and a total PITA...two batteries is not such a big deal....
    However, I did try pushing more current through my laser module, 30mA, and it now
    has a small instability...or the Rx has an issue...
    Not sure but I broke my circuit...while making it better...:confused:
    Now I've got something to do all weekend...
    cheers,
    wbg
