Thanks for replying.
Yes I'm storing all sorts of data like wind speed, rainfall, pressure,
radiation etc but the phone needs to stay live to accept remote commands
which can come at anytime.
As the phone needs to be live all the time I have no way of knowing when the
provider 'checking in' signals are being sent or received.
It is these provider initiated signals as well as my remote commands which
are affecting the readings.
It just seemed to me to be easier to detect the RF, discard the readings
during RF.
I have a spare op-amp to detect RF but have not found a reliable way of
arranging it.
Arn- Hide quoted text -
- Show quoted text -
If the cellphone is live all the time, why do you need an RF detector?
The RF will always be there. I'm still confused.
IF -- the phone is live all the time, maybe what you claim to be RF
interference is actually the cell phone hopping to another cell site -
i.e., possible power adjustment. (This occurs even in stationary,
fixed, applications). Or, path losses or other factors are causing
the cell site to intemittently adjust the cellphone output power, and
this uptick in power is what's causing your problem? Total guess, by
the way, but seems reasonable...
If the latter, one thing I would definitely check is the coupling
efficiency of your passive antenna setup. It could be a lot worse
than you think (and this could be causing additional cell hopping -
again, assuming that is the problem).
I agree a passive antenna system would not violate the equipment
cert. I could not tell from your earlier post if you were trying to
hack into the cell phone antenna jack/PCB, etc...
Either way, I guess you're still going to need your circuit, because
even if you get near-perfect radiation off your antenna systems,
there's still no guarantee the cell phone power output won't fluctuate
over time (and I'm assuming that's what your problem is as you state
previously the cellphone is powered up all the time..)
An op-amp RF detector shouldn't be too difficult to construct, but it
sounds to me that you're going to need one with an adjustable
threshold (as RF is always present). Good luck.
BTW, you must have a really expensive phone bill??
-mpm
