cellphone battery charger
Discussion in 'Power Electronics' started by Phiber, Mar 2, 2013.
  1. Phiber
    Phiber
    12
    Sep 14, 2012
    one question please, if I connect a voltage output from a power supply to a cellphone battery, will the battery start charging?
    thanks
  2. Young
    Young
    47
    Feb 6, 2013
    The power from the source must be exactly the voltage required to charge d phone or what ever,then am sure it will charge but d battery must stil b in d phone and it must still b connected through d charger
  3. BobK
    7,682
    1,688
    Don't do that, the battery could explode! A charger must control the voltage / current delivered to the battery and know when to stop. Charge your cell phone battery inside the cell phone, where the correct circuitry is there to charge it.
  4. Phiber
    Phiber
    12
    Sep 14, 2012
    ok.. noted.. guess I cant use rechargeable batteries for my amp circuit.
    thank you very much
  5. Eche
    Eche
    9
    Mar 3, 2013
    Might I recommend u use a proper charging circuit such as the mcp73861 from microchip. I have a schematic available if needed ...make sure u use exact tolerances as you can destroy a battery or under charge it.
  6. Eche
    Eche
    9
    Mar 3, 2013
    Phiber..what is the voltage and mA on the battery?
  7. BobK
    7,682
    1,688
  8. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
  9. davenn
    davenn Moderator
    13,930
    1,981
    what rechargable batteries?
    what amp circuit ?
    you suddenly changed topic in the middle of a different discussion
