M
Mark Leuck
Jackcsg said:It depends. If your gateway changes, you will have to reprogram any IP
address. If a customer switches ISP's, and was using DHCP, the unit would
not need to be re-programmed. If the customer was using an "static" IP, and
they all changed, then yes. If a customer changes CS, obviously a new
address would be required. ALL of which can be done remotely, including any
Firmware changes, port assignments, IP, etc. The control panels can be
"trapped" and all programming parameters can be changed at any time, across
the Internet.
Thats one of the reasons I liked the Ademco system, don't need to reprogram
it at all
