[email protected]
I have a need to record some of my cell phone conversations for
contracts. I have purchased a Wireless Phone Recording Controller from
Radio Shack. The problem is that my phone interferes with something in
the recording device that causes an annoying buzz to be superimposed
over the conversation, making it difficult to listen to the recording.
I am using a digital voice recorder, but have also tried an anolog
microcasette recorder and experienced the same problem.
The radio shack device plugs into the 3/32" hands free headset jack of
the phone and runs on 2 AAA batts. The hands free headset plugs into a
3/32" jack on the controller. The controller plugs into the 1/8" mic.
jack of the recording device. Apparently, the radioshack device is an
audio mixer.
The sound is not present on the headset or on the other end of the
conversation. I only hear the buzz when I play back the recording. The
phone produces this interference with the recording device, even if the
two are not connected. That is, if I turn the recorder on as though I
was going to dictate into the built-in mic. and make a call from my
cell phone, without the two being connected in any way, the recorder
records the same annoying buzz. No wires, no headset, just the raw
devices.
I understand that GSM phones can cause havoc when in close proximity to
speakers, and this is a motorola v220 gsm phone. So when I did same
test above, I was able to eliminate the interference and the buzz sound
by moving the cell phone 8 feet or so away from the recording device.
But, even at that distance, with the phone connected to the recorder
through the controller, the buzz reappeared.
The above experiment suggests that the interference can be eliminated,
if I can prevent the signal from entering the recorder through the mic.
wire.
Suppose I move the recording device far enough away from the cell
phone, or shield it by placing it in a metal box. Now, can I eliminate
the buzz that seems to be transmitted through the mic-in wire? Is
there a filter, a choke or some other device I can place between the
controller's mic plug and the mic-in jack on the recorder? If there
is, where can I buy it and how would I go about installing it or
building it if I have to? I have very little radio electronics
experience. Or, should I just scrap the scheme I am using now for an
alternative interface?
Please help.
TIA,
Jeff
audio mixer.
devices.
wire.
Please help.
TIA,
Jeff
