Cell phone generations modulations schemes, access points, and protocols
Discussion in 'General Electronics Discussion' started by dietermoreno, Feb 17, 2013.
  1. dietermoreno
    dietermoreno
    238
    Dec 30, 2012
    I have some questions about cell phone generations regarding modulation schemes, access points, and protocols after I read some tutorials on how cell phones work.
    Is this correct as follows?:
    1G
    Modulation
    modulation scheme: FM (analog)
    Amplification
    RF gain stage: class A transistor
    AF gain stage: class A transistor
    modem gain stage: N/A
    Frequency Synthesis
    Synthesis circuit: phase locked loop
    Type of phase locked loop: analog
    Voice
    access point for voice: control channel frequency codes
    voice protocol: analog
    voice service: GSM
    encryption: unencrypted
    codec for voice stream: N/A
    data transmission and reception rate for voice (synchronous): N/A
    duplex: yes
    duplex type: separate channel for each direction of the conversation using a different frequency
    Text messages
    access point for text messages: can not receive or send text messages
    protocol for text messages: N/A
    text service: N/A
    file type for text messages: N/A
    maximum file size of text message: N/A
    data transmission rate for text message: N/A
    data reception rate for text message: N/A
    duplex: N/A
    duplex type: N/A
    Photos
    access point for photos: can not receive or send photos
    protocol for photos: N/A
    photo service: N/A
    file type for photos: N/A
    maximum file size of photo: N/A
    duplex: N/A
    duplex type: N/A
    Videos
    access point for videos: can not receive or send videos
    protocol for videos: N/A
    video service: N/A
    file container for videos: N/A
    codec for videos: N/A
    duplex: N/A
    duplex type: N/A
    Internet
    access point for internet: can not connect to the internet
    IP address: N/A
    protocol for internet: N/A
    internet service: N/A
    file types from internet supported: N/A
    total data rate: N/A
    duplex: N/A
    duplex type: N/A
    2G
    Modulation
    modulation scheme: FM (digital)
    Amplification
    RF gain stage: op Amp
    AF gain stage: op Amp
    modem gain stage: op Amp
    Frequency Synthesis
    Type of phase locked loop: digital
    Voice
    voice service: GSM
    voice protocol: CDMA
    encryption: CDMA
    codec for voice stream: Windows Media Audio mono 8,000khz sample rate 4kbps bit rate
    duplex: Yes
    duplex type: separate channel for each direction of conversation using different frequency
    Text messages
    access point for text messages: control channel frequency codes
    protocol for text messages: dial up CDMA
    file type for text messages: *.txt
    maximum file size of text message: 160 bytes
    data transmission rate for text message: 80 bytes/second
    data reception rate for text message: 80 bytes/second
    text message service: GSM and SMS
    duplex: No
    duplex type: N/A
    Photos
    access point for photos: control channel frequency codes
    protocol for photos: dial up CDMA
    photo service: GPRS
    file type for photos: *.JPEG
    maximum file size of photo: 100kb
    max data rate: 144kbps
    duplex: No
    duplex type: N/A
    Videos
    access point for videos: control channel frequency codes
    protocol for videos: dial up CDMA
    video service: GPRS
    file container for videos: *.MPEG, *.MPG, *.MP4, *.FLV, *.3GP, *.WMV
    codec for videos: a codec that will force to 240p 1,000kbps video and 44.1khz 16 bit mono 64kbps audio
    duplex: No
    duplex type: N/A
    Internet
    access point for internet: control channel frequency codes
    IP address: dynamic IP address assignment assigned by tower
    protocol for internet: HTTP over CDMA
    file types from internet supported: *.html, *.js
    max transmit data rate: 44kbps
    max receive data rate: 100kbps
    duplex: Yes
    duplex type: dial up connection over voice channels
    3G
    Modulation
    Amplification
    Frequency Synthesis
    Voice
    voice service: GSM
    encryption: CDMA
    duplex: Yes
    Text messages
    Photos
    protocol for photos: broadband CDMA
    photo service: GPRS
    maximum file size of photo: as big as camera resolution will allow
    max data rate: 1.5Mbps
    duplex: No
    duplex type: N/A
    Videos
    protocol for videos: broadband CDMA
    Internet
    file types from internet supported: *.html, *.js, *.JPEG, *.MPEG, *.MPG, *.MP4, *.FLV, *.3GP, *.WMV, *.WAV, *.mp3,
    *.AAC, *.FLAC
    transmit data rate: 500kbps
    receive data rate: 1Mbps
    4G
    Modulation
    modulation scheme: QAM USB
    Amplification
    Frequency Synthesis
    Voice
    access point for voice: IP address
    voice service: 4G LTE
    voice protocol: IP
    encryption: IP
    duplex: Yes
    duplex type: USB over IP
    Text messages
    Photos
    access point for photos: IP address
    protocol for photos: IP
    photo service: 4G LTE
    duplex: Yes
    Videos
    access point for videos: IP address
    protocol for videos: IP
    duplex: Yes
    Internet
    IP address:static IP like on PC unless use proxy
    protocol for internet: HTTP over IP
    *.AAC, *.FLAC
    max data rate: 4Mbps
    transmit data rate: 1Mbps
    receive data rate: 3Mbps
