cdrom reader repair hint : door doesn't open
Discussion in 'Electronic Repair' started by Matthieu Benoit, Apr 11, 2005.
  1. Hello,
    I am trying to repair a cdrom reader LG 52X MAX
    (GOLDSTAR Model : CRD-8522B)
    Which problem is that door can't open : it seems blocked
    but if I manually help with a metal wire through de hole
    it opens correctly , and when fully opened it seems to close
    again in few seconds ; then in order to make the cd readable
    I have to push a bit on the door;
    I have fully opened the mechanics and I have not noticed nothing
    special that would be wrong :
    could you give me hints about such a failure which I have
    noticed happens often on cdrom reader.
    could it be an electronical problem ? if so what ?
    what do you advise me to do?
    I thank you for any hint,
    If you have interesting links that explain cdrom repair, I am
    interested,
    Matthieu
  2. Well you should look at the FAQ for CD repair at http://www.repairfaq.org
    Realize that there are two switches inside the drive. One tells the
    electronics that the door is open, the other that it is closed.
    If one of those switches has gone bad, or are somehow not be activated
    when they are supposed to, the electronics won't know the state of
    the door. Then it can't decide whether it should be operating the
    motor to open the door, or operate the motor to close the door, or
    just sit there.
    Micahel
  3. Ken
    Ken Guest
    Along the line of what Michael said, the switches often do not close
    properly if the mechanics don't fully reach the expected end of their
    travel. There are gears and pulleys that may be obstructed or dirty, or
    even have a loose drive belt, and not fully reach their fully open or
    closed point. Open the drive and I think you will see what I mean.
  4. Thank you very much both for your explainations,
    owing to what is written above I have succeeded to repair the unit by
    replacing the gear and pulley in the right position (just pick it off
    and pick it in), verify the belt and now it works fine, also eliminated
    dust.
    thank you very much,
    Matthieu
