L
logjam
I have a project that requires a 4050. I bought around 50 CD4050BE
ICs, but none of them work in place of the old (vintage 1975)
CD4050AE.
I lifted legs 2 and 3 out of the IC socket, attached my scope to leg 2
and connected leg 3 to leg 1. This should have caused pin 2 to go
high according to the data sheet. The input threshold for high is
supposed to be 3.5v. Pin 8 is a good hard ground. The voltage supply
is 5.02v. The CD4050BE (new ones) were pulling the inputs down from
4.5-5v down to 2.5v (there is a 47ohm resistor in front of the
inputs). With the CD4050AE part the inputs are not pulled down.
So either I got an entire tube of bad parts, or the AE / BE indicates
something important? I haven't been able to find a data sheet
specifically for the CD4050AE.
I have tested a vintage 1975 MC14050CP is known to work in place of
the CD4050AE for this application.
I will continue to try to find the data sheet.
Right now I am going crazy. I have tried 8 or so parts from the
tube. I wouldn't imagine the whole tube would be bad. Even in a test
circuit I can't get anything out of them... : ( Even if the voltage
was not high enough to be "high", it was sure loading the inputs a
lot...
Grant
CD4050AE.
lot...
Grant
