CD Tray Won't Open
Discussion in 'Troubleshooting and Repair' started by SybilK, Jan 9, 2016.
  1. SybilK
    SybilK
    Jan 9, 2016
    I have a Panosonic Stereo System SA-AK29. I can't get any of the CD trays to open up. I've tried unplugging it on the outside chance it would reset but none of them will open. Any suggestions?
  2. Alec_t
    Alec_t
    3,000
    813
    Jul 7, 2015
    Welcome to EP!
    If the rest of the system is working ok then my guess would be that a common power supply to all the tray motors is missing/weak.
    Any chance you can post a schematic?
  3. EK61
    EK61
    49
    4
    Jan 5, 2014
    Try pressing on the draw repeatedly while pressing the open button. Our unit does this too. Could be a worn out belt also.
  4. Martaine2005
    Martaine2005
    3,596
    979
    May 12, 2015
    Apart from the above suggestions. I would guess that a disc is stuck.
    This unit stacks the discs rather than having a circular 5 disc tray.
    What makes this worse is that the other 4 discs are held up above the tray.
    You may have to open the casing and manually remove the discs.
    They are located at the top, so easy to get to.
    Martin
  5. EK61
    EK61
    49
    4
    Jan 5, 2014
    Eh? [​IMG]
    Single disc
  6. Martaine2005
    Martaine2005
    3,596
    979
    May 12, 2015
  7. EK61
    EK61
    49
    4
    Jan 5, 2014
    Well, if it has a slot that sucks up the disc, then I suggest using a pair of credit cards or similar items to push the disc inside up or down in case it doesn't line up with the opening. (The stereo in our ute requires that)
  8. shrtrnd
    shrtrnd
    3,827
    520
    Jan 15, 2010
    And if all that fails, open the cabinet up and take a look at the mechanism.
    Maybe a plastic part broke.
  9. elebish
    elebish
    177
    12
    Aug 16, 2013
    Look for a small hole in the front of the disc case and use a paper clip wire to push one end into the hole to release the tray. If no hole, you will have to remove the case. Ed.
