CD player read problem
Discussion in 'Troubleshooting and Repair' started by BrianL, Sep 27, 2012.
  1. BrianL
    BrianL
    13
    Dec 9, 2011
    I've got an Onkyo DX-C390 carousel CD player that won't read the CD until I eject and and close the tray (to make it read again) about a dozen times. What causes this?
    Also I *think* it reads OK once it warms up (ie. after playing once CD).
  2. Timescope
    Timescope
    43
    Aug 30, 2012
    Some CD players have a small rubber drive belt under the tray for loading that may be worn out.
    Timescope
  3. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Try this, cut some small pieces of masking tape and place them around the hole of the CD on top (aka not the mirrored side) do this around the entire hole... Now try it... If it works than the spindle that spins the CD is probably dried out and this causes the CD to slip and not spin at the proper speed... The masking tape will give the spindle something more to grip vs the slick CD surface and will temporarily fix this issue...
    Like so...
    [​IMG]
  4. donkey
    donkey
    1,300
    56
    Feb 26, 2011
    wow thats a ingenius idea, never thought of it before.
    another question is how often do you use a cd cleaner? the laser may have something on it. try not to use home remedy cleaners as most leave a residue and residue = bad laser reads
  5. Harald Kapp
    11,813
    2,752
    I cleaned the spindle with a soft cloth dipped in pure alcohol. Worked a charme in my case.
    I never used a lens cleaner. If necessary, pressurized (canned) air can remove dust. Lacking pure pressurizes air I used cleaning spray for video recorder heads. Leaves no residues and works well.
  6. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    I discovered that trick long ago when CD/DVD players for computers were actually costly... My $400 (I can't believe they used to cost that) DVD burner on my computer had a spindle issue and I discovered the masking tape trick to milk some more time out of the drive before replacement...
    Getting into the drive and actually cleaning (or replacing) the spindle like Harald suggest is the best option, but the masking tape works and will help narrow down if that is the problem...
  7. BrianL
    BrianL
    13
    Dec 9, 2011
    Unfortunately that doesn't seem to be the problem with mine. I tried it anyway to be sure, but it's not even trying to read the CD. It doesn't make any noise (well except one very faint click). And I have to eject it and close it again for it to try again. Usually after about 20 tries, it will read it and make the squeaking noise they usually make when reading (which I think is the servo motor that moves the laser unit on it's rails). But tonight I tried about 50 times and couldn't get it to read.
  8. donkey
    donkey
    1,300
    56
    Feb 26, 2011
    I don't know the indsides of CD players too well but I am assuming there is a switch or something that would detect the CD inside which would initialise the laser.... or the laser itself might do that. would that be an area of concern?
  9. grant1842
    grant1842
    11
    Oct 1, 2012
    All so I have replaced bad CAPS that cause this Disc Read Error . So I would check the SMPS pcb, and the other boards as well.
  10. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Fire it up with the cover off and see what it happening or not happening, it might give you some insight...
