Cd Player Problems
Discussion in 'Electronic Repair' started by [email protected], Feb 16, 2007.
  1. Guest
    Hi all I am new here so hope that I am posting this in the correct
    place. I have recently bought a more modern car ( fiesta mk5) and I
    am
    having an issue with CD playback. The Cd will play fine for sometimes
    20 or more mins and will then turn itself off without warning. If I
    then try and turn the player on the on/off button does not appear to
    function. However five to 10 mins later it will come on for few
    seconds then turn off again.
    When I got the car the battery was very low. This has improved since
    I
    have been driving it. Could this be the cause of the cd playback
    problems?
    The cd player model is a 6000 rds cd E.O.N.
    Any of your thoughts or suggestions would be appreciated.
    Gardnjam
  2. Hi!
    I would say there is a distant possibility that a deeply discharged battery
    could cause this problem. The average alternator can require a long time to
    fully charge a low battery. During this time, the quality of power coming
    from the vehicle's electrical system can vary widely. How old is the
    battery? It could be worn out.
    It would also be a good idea to check for loose contacts, fuses or other
    radio related wiring. Check the speaker wiring--if it is shorting out, it
    could cause the radio to shut down to protect the power amplifier.
    William
  3. Guest
    Hi Will thanks for your reply. I beleive I have now found the reason
    for my problems. The front of the cd player fascia appears to have a
    loose connection. When I press it in it turns back on again. Cheers
    I'm now heading in the right direction to solving problem
