CD changer
Discussion in 'Electronic Repair' started by GD, Apr 20, 2005.
  1. GD
    GD Guest
    I have a cd changer that works well most of the time, but occasionally
    when I try to play it I get ERROR message and it won't play. I keep
    opening and closeing the carosel door, or turning off the power source,
    and eventually it will work again. I have looked for obvious things
    such as dirty lazer lens, cd out of alignment with spindle, and all
    seems fine there. Is there something I can check to find out what the
    problem is? Any suggestions would be appreciated. Thanks
  2. GD wrote:
    Brand and model info would help.
    Cleaning problems account for the majority of issues like this.
    Mark Z.
  3. jakdedert
    jakdedert Guest
    He cleaned (he said). OP: do it again. While you have it open, check for
    binding/proper lubrication in all of the mechanism.
    Most importantly: reseat all ribbon cables.
    jak
  4. GD
    GD Guest
    Thanks I will go over it again, At the moment it is playing fine, but it
    gave problems until it got warm in case. I left it on tried it again
    later, and it worked. Not sure if that will fix always
    Thanks Again
  5. GD
    GD Guest
    The unit is a Sherwood CDC-503DR
