CD Changer Repair Question
Discussion in 'Electronic Repair' started by Adam, Sep 23, 2004.
  1. Adam
    Adam Guest
    Hi All
    I have a CD changer from my Jeep that I've been working on repairing.
    I've come to quite a dead end, and any help would be extremely appreciated!
    Here's the background story:
    Over a period of a few months the cd player began to work only
    sporadically--sometimes it would play discs, other times it would just
    read out ERR on the screen. Eventually, it would just ERR all the time.
    I replaced the optical laser pickup assembly -- this is the unit with
    the lens, some electronics, and the screw-gear to move it up and back
    across the CD.
    I also cleaned the two optical sensors that check for the cd-cartridge
    and for a loaded cd onto the reader mechanism.
    NOW, the player will load discs properly, start to spin them up and then
    stop, and the readout will again be ERR. Is it possible that its a bad
    spindle motor? Is there anything else I should check? I'm clean out of
    ideas.
    Thanks again for any help!
    -Adam
  2. Eugen T
    Eugen T Guest
    Did you remove safety "feature" from laser pickup? i.e. there is usually
    jumper in circuit to protect laser during shipping...
  3. Usually a solder "blob" covering 2 adjacent foil pads. Needs to be
    desoldered.
    Mark Z.
