CCTV Monitors
Discussion in 'Security Alarms' started by Sparks, Apr 2, 2005.
  1. Sparks
    Sparks Guest
    Not ure if this is the correct group, if not can someone show me the way!
    CCTV monitors seem to usually be 1000 lines,
    would there be any problem using a LCD TV with composite video in?
    The one I am looking at is 17" - 1280x1024
    Ta!
    Sparks...
  2. Aegis
    Aegis Guest
    http://www.americandynamics.net/products/monitors_home.aspx
    has LCD monitors specifically for CCTV applications with BNC-style composite
    video input connectors
  3. Jackcsg
    Jackcsg Guest
    It's only going to be as good a resolution as the camera you put in to it.
    Raster to Vector.
  4. Guest
    An LCD will never be as good quality as a CCTV Tube Monitor.
    The only type of LCD that will give you reasonable quality, will be a
    CCTV designed LCD which normally start around $700 for a 15". Look for
    one from a CCTV Manufacturer, such as Kalatel, AD, Bosch, Ultrack, etc.
  5. Sparks
    Sparks Guest
    This is what I was worred about, however, if the LCD has 1024 lines one way,
    and 1280 the other, surely this is better then a 1000 line CRT?
    Sparks...
  6. Jackcsg
    Jackcsg Guest
    They will both look the same with a camera of 480 Lines of resolution hooked
    up to them. Only your mind will decide the LCD is better because you paid
    more money for it.
    Again, Raster to Vector. It's a mathematical equation. It's like buying an
    HD ready TV, and placing it on a UHF antenna.
  7. Scott Berg
    Scott Berg Guest
  8. Guest
    No, it wont be better. The CCTV monitor of even 500TVL will still
    provide a much crisper quality video. LCDs are not there yet.
    Rory
  9. Bob La Londe
    Bob La Londe Guest
    Most cheap LCD monitors will etch fairly quickly.
