Yanni said:
Is this possible that radio like here -
http://www.lincoln.cba.pl not
transmitting anything because of no additonal pin connection backside
of radio ??
Your link as provided - didn't open - at least not for me.
There are a few reasons it may not be transmitting. "Not transmitting" could
mean it isn't "transmitting" over a distance - or "not at all". There "is" a
difference.
1. Do you have a "Mic" wired "properly" to it - to activate the PTT relay
and provide modulation?
2. Do you have a good antenna and cable attached to it?
If the signal is not going out over the air - assuming a good mic and
antenna system, then it is possible/likely - your problem is internal to the
set. The "RF Amp Transistors" could be shot, the PLL system shut down or
shifted far enough to cause no operation.
From your question - "because of no additional pin connection backside of
radio" - not being able to see your intended picture(s) - I must wonder if
you are even using an antenna. You "should" be.
