CATV signal
Discussion in 'Electronic Basics' started by Joe, Aug 7, 2004.
  1. Joe
    Joe Guest
    What signal is carried by Cable TV? Is it VHF, UHF, anti-protons
    (lol)?
    Where I'm living now, I cannot possibly throw a cable to my room, so I
    am considering
    building a transmitter/receiver of CATV, if that's even possible
    economically for domestic use.
    Does anyone know where I can find such circuits?
    Thanks in advance.
  2. Active8
    Active8 Guest
    The first two.
    If you mean you want to broadcast CATV to your rabbit ears and loop,
    don't. The mid-band is shared with aviation and the CATV copany does
    leakage checks. You'll be interfering with peoples off air reception
    (which is on a different channel line up) and ghosting the CATV
    signal of others who may have leakage (ingress.)
    The line amps at home depot and such give varying degrees of signal
    quality and the ones outside on the line start at $700 or so and
    require a special power supply.
    *Why* can't you run a cable to your room.
  3. colin
    colin Guest
    anti protons? what about electrons or even tachyons?
    if you have line of sight maybe you could use a modulated laser beam to
    avoid interference,
    then you just have to worry about blinding everyone who looks in the wrong
    direction, or isue lots of safety glasses.
    or maybe you cld put the receiver at the far end and just transmit the
    station you want, you can get video senders wich use a gighz or so, asuming
    your remote has long range. just have to hope no one else nearby has the
    same idea..
    why do i have visions of it being in a tree house ?? (maybe its the mention
    of rabbits).
    ive often wondered what i wld see if i stuck a scope on the end of my
    cabletv/modem line, but scared of breaking it, as its NTL it might be a bit
    fragile and cld be ages before it got fixed...
    im also interested in a pc card that wld receive chanels direct from the
    cable even if its just the unencrypted ones, atm my pc vcr (ATI AIW) is
    limited cos it cant change the chanel on the receiver box, although there
    was a thread on pc controled ir remotes ...
    Colin =^.^=
