Cat 5E cabling.
Discussion in 'Hobby Electronics' started by Brian Goldsmith, Oct 11, 2005.
  1. I have just purchased two Cat 5e A type patch cords of different length
    and manufacture.Whilst both are wired identically (straight through,1 to 1
    etc.),I notice the colour codes used are different,one following the 568A
    code and the other following the 568B code.Could someone advise if a) there
    is something about Cat 5E I don't know (very possible),b)this is "common"
    practice and c) it really matter,electrons cant see colour after all!
    Thanks,Brian Goldsmith.
  2. Ross Herbert
    Ross Herbert Guest
    Brian,
    a) difficult for me to say what you already know
    b) it is common a occurrence to find both 568A and 568B in patch cords
    c) doesn't make any difference in a practical sense
    I have seen patch cables sent out with Cisco routers and they don't
    even conform to any known wiring colour or terminating standard.
    Needless to say they are all Chinese origin. While the Australian
    recommendation is for structured cabling to be terminated to 568A
    there is no problem with doing it to 568B.
    ***** Well,I believe the answer is first of all,a) followed by b) followed
    by c)!!!!!!!!!!!!!!!!!!!
    Please see the following which I have just discovered in a google search.
    "The 568 committee, with good intentions, decided to allow both wiring
    methods (568A & 568B) to exist within the 568A Standard. The reason was that
    at the time, a great deal of cabling plants had been installed to the B
    standard (formerly known as WECO or AT&T 258A). Even though they allowed
    both wiring methods, they stated in their standard that 568A wiring would be
    the preferred method for all new installations. Time, and popular opinion,
    went in the other direction. The most popular wiring method today is 568B.
    Having both A & B methods does nothing but cause errors and confusion.
    Originally, patch panels and jacks were manufactured either A or B. In most
    cases, they were not labeled as such. Most suppliers stocked only the B
    wired products. Luckily, today, almost all jacks and patch panels show
    diagrams for both A and B. The only difference between the two is the
    interchanging of the 2nd and 3rd pairs (white/orange and white/green,
    respectively)."
    What a typical septic dogs breakfast!!! :)
    A bit like the US satellite that "blew" up because the septics couldn't
    recognise there were some parts made to metric specs and some made to US
    Imperial!!!
    Thanks for the indulgence!
    Brian Goldsmith.
  4. Peter Howard
    Peter Howard Guest
    This is the page I refer my workmates to when they want to know how to make
    a custom length of patch cord.
    http://www.lanshack.com/make-cat5E.asp
    It cuts and pastes to Word and prints out well.
    The hard part is developing the manual dexterity to untwist those damned
    little wires, trim them to the right length and get them into the plug for
    long enough to crunch down on the crimping tool.
    As it says, there's no diff in connectivity between straight thru 568A and
    568B, though most patch cords seem to be 568B. Naturally, if you need a
    crossover cable you need one A end and one B end.
    PH
