B
Ben
Hiya,
This is for a college exercise (non-electronic engineering module), but
the module is about designing a program to calculate the best ordering
of transformers to give the maximum input current, not about how to
actually calculate the maximum input current, and we haven't really been
told how to calculate this, hence why I am asking:
If I have 3 ideal transformers, I know the turns ratio and their maximum
input and output currents.
I can work out the following, Iout(max) = Iin(max)/n, where n is the
turns ratio.
Say I am given three transformers, with the following data
T1: Turns ratio =2, Iin(max) = 2.7, Iout(max) = 2.1
T2: TR = 1.5, Iin = 0.2 Iout = 0.3
T3: TR = 1.2 Iin = 0.3, Iout = 1.6
How would I calculate the maximum input current that could be applied to
the whole cascade bearing in mind that I don't have input values.
I tried several ideas such as taking the Iin(max) of T1, working out the
Iout by using 2.7/2 = 1.35A, then trying to find a transformer that
would accept that Iout, but obviously, this doesn't work as none of the
other transformers will accept 1.35A without blowing out.
One idea I am toying with is working backwards, taking a transformer,
using its max Iout, working out the Iin at that output current, and
finding a transformer that outputs that current or higher, then working
out the Iin of that, and so on...
Any help/pointers would be appreciated.
Ben
turns ratio.
Ben
