Car radio static
Discussion in 'Radio and Wireless' started by webco, Aug 15, 2018.
  1. webco
    webco
    4
    Aug 15, 2018
    Here's one for you... The Pioneer radio in my truck (2001 Chevy Silverado Pickup) works perfectly when the engine is running and transmission is in park. When I shift out of park, the static is so bad I have to shut the radio off! I have no clue what would be causing this. Help!
    Bill
  2. davenn
    davenn Moderator
    13,260
    1,748
    hi ya Bill
    Welcome
    engine running or not in above scenario ??
    if running and noisy, is it diesel or petrol engine /
  3. dave9
    dave9
    770
    171
    Mar 5, 2017
    ^ I suspect petrol because it's usually related somehow to the ignition system, that putting it in drive changes the engine RPM just enough to be a problem.
    Has it always been like this or has it gotten worse? If it has gotten worse I would suspect dried up capacitors in the radio or the antenna connection has corroded, or damaged spark plug wire(s). I'm suggesting you have poor signal to noise ratio then the question is whether the signal needs increased or the noise decreased.
    If it was always like this, I would wonder about the state of your spark plug wires. Are they a deviation from the stock resistive carbon conductor wires, a solid copper or wire core instead? Are they damaged and arcing against the engine (or another ground) ? Is it possible your radio has a bad ground connection?
  4. Audioguru
    Audioguru
    2,571
    580
    Sep 24, 2016
    Static sounds from a radio are Amplitude fluctuations which are AM. An AM radio picks up lots of static interference but an FM radio ignors amplitude fluctuations and is quiet.
    I never use AM radio and always listen to FM radio so I hear no static.
  5. webco
    webco
    4
    Aug 15, 2018
    It's when the engine is running and it's petrol.
    Thanks!
  6. webco
    webco
    4
    Aug 15, 2018
    It's a petrol motor. The RPM change is not noticeable. I just got the vehicle so i don't know it it always did it or not. It's not the original radio. Thanks!
  7. Audioguru
    Audioguru
    2,571
    580
    Sep 24, 2016
    A cheap or defective FM radio picks up AM static. A good FM radio does not.
    You never said if the static is heard on AM (it normally pick up static) or FM.
  8. webco
    webco
    4
    Aug 15, 2018
    Happens AM or FM
  9. ramussons
    ramussons
    340
    61
    Jun 10, 2014
    My guess is that some electronic module comes into play when the drive is shifted. And this has some bad radiation causing static.
Similar Threads
Loading...
