Car Radio powered by PSU
strokeface
Jan 4, 2012
Jan 4, 2012
Does anyone have an easy to follow plan for hooking up a car stereo with a psu from a computer and speakers inside? I found some stuff saying to convert the psu and some say it doesn't matter. Thanks for the help anyway
MattyMatt
Mar 24, 2011
161
Mar 24, 2011
161
I am assuming you are talking about a 12V car stereo (that mount in the dash), and you want to bring it inside the house to either a 110V or 220V system.
If this is the case, then I would suggest getting a nice power supply (12 - 13.8V DC output) I would say getting one that is designed to power HAM radio equipment would be the best, as they tend to be very well built. As far as the speakers go, it would be just a matter of following the instructions of the radio (assuming its after market) to connect them properly.
If you need to get things like amplifiers and sub-woofers working, this would require a few more things like possibly a car battery to run them from, and a good sized capacitor that is designed for car audio. Not to mention a way to charge the battery after you were done using the extra bits.
Matty-
davelectronic
Dec 13, 2010
1,087
Dec 13, 2010
1,087
Hi there.
Car battery's indoors can be dangerous, if you have add on's amps etc opt for a multi voltage output unit, or if voltages are roughly the same a bigger power supply, i know 60 amp retail units exist, but i doubt your need anything that big. :)
