Car horn as speaker for musical keyboard
Discussion in 'Audio' started by Vikrama Chandar, Jul 7, 2018.
  1. Vikrama Chandar
    Vikrama Chandar
    4
    Mar 12, 2017
    I have an idea to build a circuit which picks up audio from the audio out of keyboard & plays it via the car's horn. Is it possible? If so suggest me how.
  2. dave9
    dave9
    867
    213
    Mar 5, 2017
    lol, depending on the car horn design, sure it's possible. Now you need to provide the specifics you should have in the first place.
    Wait, you mean just a simple stock horn? No in that case you'd want a PA-style speaker in its place. So it's do-able but you need the PA speaker.
  3. Bluejets
    Bluejets
    3,784
    783
    Oct 5, 2014
    Most electric car horns operate by moving a metal disc which in turn opens and closes a set of pre-adjusted points, much in the same way as an electric bell.
    Speakers operate by applying a variable to a speaker coil that is surrounded by a magnetic field.
    Totally different principles.
    kellys_eye likes this.
  4. kellys_eye
    kellys_eye
    4,277
    1,146
    Jun 25, 2010
    I once had an idea to record different vehicle sounds and replay then via a horn speaker secreted under the car somewhere. The system would have used throttle load to vary the tone/pitch of the sound.
    You would have been able to select 'steam train' for example and 'chuff, chuff' away at traffic lights or the noise-some drone from a 2-stroke scooter or even an expensive Ferrari :p
    Then I grew up :D
    allegedly.
    darren adcock likes this.
  5. Kiwi
    Kiwi
    321
    73
    Jan 28, 2013
    Boys should never "grow up". Our toys should just get bigger, flasher, and more expensive!
    As Bluejets explained, a car horn won't work as a speaker.
  6. FuZZ1L0G1C
    FuZZ1L0G1C
    367
    115
    Mar 25, 2014
    A horn speaker (ie Megaphone type) uses a driver (voice-coil and magnet) with several folded horns in front.
    Although suitable for amplifying the human voice, trying to reproduce the full range of a musical keyboard through any type of horn is difficult, if not impossible.
    As already mentioned, car 'horn' and 'horn' loudspeaker, although names appear similar, use different technologies.
  7. Bluejets
    Bluejets
    3,784
    783
    Oct 5, 2014
    Ahh...nothing like a Wes Harrison mod to your car....
  8. Hopup
    Hopup
    239
    31
    Jul 5, 2015
    I think they do use speakers in some sports cars because the low emission (small) engines won't give enough sound out. Also there's lot of products like this, which are kind of cool I guess.
  9. kellys_eye
    kellys_eye
    4,277
    1,146
    Jun 25, 2010
    I believe they've even fitted 'speakers' to the F1 cars as the new hybrids aren't anywhere near as loud as the original normally-aspirated versions! The spectators were getting disappointed at the lack of 'noise' so the F1 authorities made the car manufacturers fit some sort of noise amplification device!
  10. Bluejets
    Bluejets
    3,784
    783
    Oct 5, 2014
    Must be surround sound as those mothers are noisy in any direction.
