capture module problem
Discussion in 'Microcontrollers, Programming and IoT' started by ami85t, Mar 31, 2014.
  1. ami85t
    ami85t
    71
    Feb 19, 2014
    Hi to all and thanks to all how helped my till now in my project,
    I'm using a PIC16F877 and for some reason it's capture module doesn't work.
    A loop in my code which job is to wait for the flag announcement of capturing
    isn't set and there's a infinite loop of waiting for that to happen.
    A DMM which is connected to the CCP2 leg shows a frequency but I'm not sure that
    its a true value there, (although I have already seen that it measures exact frequency
    and duty cycle) since it shows sometimes also a frequency when disconnected.
    have I done the configuration and capture loop correctly?
    The other sections of the code work properly.
    Thank,
    Amitai
    Code:
    LIST	P=PIC16F877
    include	<P16f877.inc>
    org		0x00
    	__CONFIG _LVP_OFF &_WDT_OFF &_PWRTE_OFF &_CP_OFF & _HS_OSC
    	reset:
    	nop
    	goto	start
    	org		0x20
    start:
    ; configuration
    ; used_ registers:
    	MUX_sel			EQU H'0021'  		; for not transmitting '000000000'
    	del1			EQU H'0030'  		; for delay
    	del2			EQU H'0031'  		; for delay
    	to_transmit		EQU H'0050'  		; Frequency data register
    	led1			EQU H'0070'  		; for led delay
    	demo_tr			EQU H'0072'  		; demo transmit
    	loop_mux		EQU H'0074'  		; demo transmit
    	banksel		ADCON1
    	movlw		0x07				; ADC PINS configured as a digital I/O
    	movwf		ADCON1
    ;UART/*/*/
    	banksel		TRISC
    	bsf	 	 	TRISC, 6
    	bsf		 	TRISC, 7
    	banksel  	TXSTA
    	movlw    	0xA7        		; master, transmit EN, Async mode, Transmit Shift Register empty, BRGH =1
    	movwf    	TXSTA	       		; Baud Rate = Fosc/(16(SPBRG+1)) , BRGH (baud rate) ignored in sync
    	banksel		SPBRG
    	movlw	 	0x03		   		; = d"16" which corresponds to 125Kbps with 8MHz clock
    	movwf	 	SPBRG
    	banksel  	RCSTA
    	movlw    	0x80		  		; enable UART
    	movwf    	RCSTA
    ;PWM, timer2/*/*/
    	banksel		TRISC
    	bcf			TRISC, 2 			; make the CCP1 pin an output.
    	banksel		T2CON
    	movlw		0x04
    	movwf		T2CON				; no post/Prescaler (1:1) , TMR2 ON
    	banksel		PR2					; output frequency = 15000hz 	=
    	movlw		0x84
    	movwf		PR2					; 1 / [(PR2) + 1] • 4 • TOSC •(TMR2 prescale value)
    	banksel		CCPR1L				;duty cycle =(CCPR1L:CCP1CON<5:4>) • TOSC • (TMR2 prescale value)
    	movlw		0x42				;           = 267 *1/8MHz = 50% d.c.
    	movwf		CCPR1L
    	banksel		CCP1CON
    	movlw		0x3C
    	movwf		CCP1CON
    ;capture, timer1 /*/*/
    	banksel		TRISC
    	bsf			TRISC, 1 			; make the CCP2 pin an input.
    	banksel		T1CON
    	movlw		0x09				; Timer1 Input Clock Prescale 1:1, en TMR1
    	movwf		T1CON				; , int clk (fosc/4) , oscillator en
    	banksel		CCP2CON
    	movlw		0x07
    	movwf		CCP2CON				; Capture mode, every 16th rising edge
    	banksel		PIE2
    	bcf			PIE2, CCP2IE		; avoid false interrupts
    ;MUX select
    	banksel		TRISD
    	bcf			TRISD, 0
    	bcf			TRISD, 1
    	bcf			TRISD, 2
    ;LED general delay
    	bcf			TRISD, 4
    	bcf			TRISD, 5
    	banksel		PORTD
    	bcf			PORTD, 4
    	bcf			PORTD, 5
    ; end configuration --------------------------------------
    ;************ MAIN PROGRAM ***************
    main:
    ;MUX init
    	movlw		0x07
    	movwf		MUX_sel
    	movlw		0x08
    	movwf		loop_mux
    ;transmit check /*/*/*/*
        movlw		0x05					; demo check
    	movwf		demo_tr
    	tra:
    	CALL		DELAY
    	movf		demo_tr, w
    	movwf		to_transmit
    	CALL 		transmitting_data
    	decfsz		demo_tr
    	goto		tra
    main_loop:
    Led_flicker:
    	movlw 		0x30
    	movwf		led1
    	t2:
    	CALL		DELAY
    	decfsz		led1
    	goto		t2
    	bcf			PORTD,5
    	bsf			PORTD,4
    	banksel		led1
    	movlw 		0x30
    	movwf		led1
    	t1:
    	CALL		DELAY
    	decfsz		led1
    	goto		t1
    	bcf			PORTD,4
    	bsf			PORTD,5
    ;---end Led flicker
    ;capture frequency/*/*
    	banksel		TMR1H
    	clrf		TMR1H
    	clrf		TMR1L
    	banksel		PIR2
    	bcf			PIR2, CCP2IF
    	check_capture:
    	btfss		PIR2, CCP2IF					; 1  = A TMR1 register capture occurred (must be cleared in software)
    	goto		check_capture
    	bcf			PIR2, CCP2IF
    ;transmitting data
    	banksel		CCPR2H							; transmit MSB
    	movf		CCPR2H, w
    	banksel		to_transmit
    	movwf		to_transmit
    	sublw		0xFF				; if data = FF change to FE
    	btfsc		STATUS, Z
    	CALL		data_change
    	banksel		CCPR2L							; transmit LSB
    	movf		CCPR2L, w
    	banksel		to_transmit
    	movwf		to_transmit
    	btfsc		STATUS, Z
    	CALL		data_change
    ;MUX select/*/*/
    	movf		MUX_sel,w
    	banksel		PORTD
    	movwf		PORTD
    	decf		MUX_sel, f
    	decfsz		loop_mux
    	goto		main_loop
    	movlw		0x07
    	movwf		MUX_sel
    	movlw		0x08
    	movwf		loop_mux
    	movlw		0xFF							; send FF at end of buffers
    	movwf		to_transmit
    goto main_loop
    ;******** END MAIN LOOP ********************
    transmitting_data:
    	banksel		TXREG
    	movwf   	TXREG					    	; writing to TXREG clears TXIF
        trans_wait2:
    	btfss		PIR1, TXIF						; wait for the frame to be transmitted
    	goto		trans_wait2
    	CALL		DELAY
    	return
    data_change:
    	movlw		0xFE
    	movwf		to_transmit
    	return
    DELAY:
    	movlw		0xFF
    	movwf		del1
    	movlw		0xFF
    	movwf		del2
    	loopa:
    	decfsz		del1, f
    	goto		loopa
    	loopb:
    	decfsz		del2, f
    	goto		loopb
    	return
    end
  2. Anish
    Anish
    46
    Feb 5, 2011
    Honestly IMO, very few will be interested in going through assembly code. Better you give the algorithm as to what you are doing with the code.
    you have good comments in the initialization section. But comments are scarce after the main label somewhat difficult to follow.
    EDIT: sory I didn't see your previous threads.
  3. ami85t
    ami85t
    71
    Feb 19, 2014
    Thanks Anish, I have solved the problem
    Amitai
