[email protected]
Hi there, simple question that must be in H&H, but I can't find it. I
have a PCB with about 18 LM741 op-amps on it. I supply +/-15V to V+ and
V- via traces on the board (~1mm width -- pretty big). Now, I've heard
that you should always have a cap. to ground right at V+ and V- because
the traces on the board carrying power have inductance, and you want to
be able to supply current to the op-amp fast. Is this right? I pretty
much swing the output of the op-amps from 0 to -10V at no faster than
~1kHz. If so, what is a good value? I assume uF-ish is fine.
Thanks!
Jesse Wodin
Thanks!
Jesse Wodin
