Cappacitors and electro-magnets
Discussion in 'General Electronics Discussion' started by powers, Mar 10, 2011.
  1. powers
    powers
    4
    Mar 10, 2011
    I am working on a project and need some advice. I'm not very knowledgeable with electronics but I'm working on it. So here are a couple questions for you knowledgeable people out there.
    1) can a cappacitor be ruined by overcharging it?
    2) If I were to build a High Voltage electro-magnet, can it handle long term high voltage or must it only be for a second? in otherwords will it burn through coating and short out?
    3) What is the best way to make 1000 volts DC?Can it be done starting with 12 volts.
    4) where can I purchase a large roll of #30 coated wire? say 10 pounds.
  2. davenn
    davenn Moderator
    13,785
    1,936
    Hi Powers, welcome
    Capacitors have a voltage rating written on them, that rating shouldnt be exceeded or it probably will go bang
    how hi a voltage ? if designed correctly, it will handle extended periods on power on
    it could be started with 12V DC or AC with 12VDC you will need a voltage multiplier. With 12VAC you will need a transformer and then rectify the voltage back to DC
    1000V DC or AC is very dangerous. Be careful that you dont prove the Darwin Theory of Evolution correct !!
    Search google for Darwin Awards, if you dont understand ;)
    you havent said what country you are in, so I cant answer that specifically maybe a hobby electronics shop or an electrical cables dealer
    cheers
  3. (*steve*)
    25,480
    2,827
    Capacitors can also be damaged by charging and discharging at high currents (even if their voltage rating is not exceeded).
    Generally speaking this is caused by heating due to internal resistance in the capacitor, so relatively few brief high current pulses may be less damaging that continuous lower ripple current at (say) 60 Hz.
  4. powers
    powers
    4
    Mar 10, 2011
    I live in Michigan, USA. These electromagnets I am going to wind with #30 coated wire or i'll send them out. they will need to handle 1000 volts DC for just a second.
    Is it possible to convert 12DC to 1000 Volts DC without using an inverter?
    By the way I am working on a fuelless engine that runs off Electro-magnets. I think I have most everything I need to start but the electronics are stumping me big time. If I could post a pic on here someone may be able to understand what I am trying to accomplish.
