capcitors in series?
Discussion in 'General Electronics Discussion' started by iloverushandledzepp, Oct 24, 2013.
  1. iloverushandledzepp
    iloverushandledzepp
    7
    Oct 22, 2013
    i hear you can put them in series.
    but, i also heard that you divide them
    i thought if you put those two the total capacity is 200? why does it go down?
    I'm new and that confuses me
    EDIT:
    i want to try connecting a few capacitors to a resistor and then an led to see how long it takes for the led to go out. to learn a little bit
  2. davenn
    davenn Moderator
    13,812
    1,945
    Capacitors in series or parallel is opposite to resistors in series
    have a read through this tutorial...
    https://www.electronicspoint.com/series-and-parallel-capacitors-t222564.html
    cheers
  3. iloverushandledzepp
    iloverushandledzepp
    7
    Oct 22, 2013
    thankyou. i have one question. what is the point of capacitors in series if it equals less like above where 2 100uf would equal 50 uf? is this to get more of a exact desired number?
  4. davenn
    davenn Moderator
    13,812
    1,945
    you may not have a 50uF handy but do have a bunch of 100uF caps
    or you just need to know the effects of a set of caps in parallel or series
    they could all be different values, when doing circuit design
    say one could be an actual capacitor where the other is the capacitance between 2 circuit tracks. This becomes critical when dealing with VHF and higher RF electronics,
    where very small capacitances can have large effects on how the circuit operates
  5. iloverushandledzepp
    iloverushandledzepp
    7
    Oct 22, 2013
    thankyou very much dave :)
