Jeroen Vriesman said:
I need to measure a capacity of 5..6 pF within 30 uS, at 0.01% accuracy.
The accuracy does not have to be absolute, doesn't have to be completely
lineair also, as long os noise and tempco don't affect the measurement more
than 0.01% it's ok. (within about 15 deg C temperatur range).
I've got some ideas, but does aynone have some realy good suggestions or
links?
Hmm. 0.01% is a bit less than 14-bit accuracy. Analog Devices and
Texas Instrument have both got 16-bit A/D converters with conversion
times around one to two microseconds, and apperture times which are a
whole lot shorter
http://www.analog.com/UploadedFiles/Data_Sheets/31038630530425AD7653_a.pdf
for the Analog Devices AD7653 gives an acquisition time of 0.25usec.
I'd make myself a a very stable 5uA constant current source, and
direct it into the commoned sources of a pair of SD214 lateral
MOSFETs. Switch this into your capacitance for 1usec to produce a
roughly 1V step. Buffer the voltage across the capacitor with a fast
FET-input op amp - the OPA655 comes to mind - and digitise the op amp
output. Use a third SD214 to discharge the capacitor to ground (or
some other stable voltage) for, say, 1usec. Turn off SD214, and wait
for the capacitor voltage to stabilise again, then digitise the
starting voltage.
This connects two SD214 aysmmetrical lateral MOSFET transistors to the
capacitor, adding about 1.5pF per transistor to the capacitance being
measured,
http://www.linearsystems.com/datasheets/SD214.pdf
while the OPA655 adds another 1pF
http://focus.ti.com/lit/ds/symlink/opa655.pdf
You'd probably need to use the circuit to measure just the capacitance
of these parts as a function of temperature (at half the current) to
have any hope of maintaining 0.01% accuracy on the capacitance you
want to measure.
The job seems to be do-able, but the 0.01% might be difficult to
achieve.
It would be easier if you could find a 5.6pF capacitor that was stable
to better than 0.01% over the temperature range that you want to
cover, but
+/-30ppm/C ceramic disks would seem to be the best you could get and
that is +/-0.01% in +/-3C.
